Locking doors
jmarch58
yuba city ca
Hey guys I want to get some sort of lock for the doors of my truck where should I mount them on the door to not mess up the internal working on a m923a2
rhurey
14
Bothell, WA
Any 5/16 square handle will work. I've got garage door handles on mine. In all honesty, by the time I paid $33 for the handles & Allen screws, tried to paint the chrome, cut the too long shafts down to size, I wish I'd just paid the extra $30 and got the ones from TMG. Saved some money, and spent an extra hour or two fiddling with it.
dawico
Lampasas,TX
Just today I put a slide bolt that latches my driver's door from underneath. I drilled a big hole directly under the door in the edge of the cab and mounted it inside. The slider slides up into a hole in the bottom of the door. It is totally hidden unless you look for it and a I can add a padlock if needed. The passenger door is combat locked from the inside.
My truck has a soft top so I am not too concerned about security but every little bit helps.
Merc1973
Sykesville, MD
I also used Those Military guys just for the driver's side. Mine did not fit properly. The screw mount holes did not line up and had to be drilled out slightly.
Those Military Guys
Rancho Cucamonga, CA
Here is a link to the battery keyed cut off. We also do offer the locking door handles and like posted we have taken all the guess work out of it by the time you go through all the figuring out and all the costs you will more then likely have spent more we do are best to costs down to help the MV owners enjoy there trucks without hurting their wallets i hope we can help you in the future
thank you
TMG
http://www.steelsoldiers.com/showth...battery-cutoff-switch-for-your-military-truck
