Lolly-Pop lights
Billy Bobbed
13
Terre Haute,Indiana
I ordered a set of lollipop lights plus brackets and side markers today from saturn surplus.Does anyone sell the metal bracket that the side marker bolts to or is that to be custom made.Looks to be no problem to make just need the sizes or a good look at how they are made.Are the wires spliced in or do they use double connectors.
Castle Bravo
Hundredaire Socialite
231
Arizona
I too would like to find a source for the side clearance/marker light brackets. Is anybody out there making them? I think they're just a rectangle with a diagonal fold and some holes drilled in them.
wsucougarx
Washington State
The front side light bracket (mounts to front turn signal guard) can be found at Saturn. The one's mounted on the bed are nothing more than a piece of angle iron with holes.
hndrsonj
Senior Chief/Moderator
375
Cheyenne, WY
If someone could post the specs from one they have, the front would be very easy to make too! (flat steel with a 90 degree bend)
wsucougarx
Washington State
I attempted to install the Lollipops today. I used a jumper and patched the lollipop onto wire 460/461 (signal lights) and now my flasher don't work anymore. Oops, how did everyone else wire their lollipops? Oh, I am using them as turn signals in the rear facing configuration along with using the standard turn signal as well. When I flip on my turn signal lever, the indicator light just lights up with no apparent flashing.
