Long or Short Injectors
mcne2026
Kuna, ID
There are two basic injectors for the 6.2 & 6.5 motors. I am in CA and my CUCV is in ID so I can not go out and check this. Do our 6.2's use the short or long injectors? I can not remember what year they made the change. I am going to change out my injectors this year and have 4 good short injectors already, so I am hoping it uses the shorts. TIA, Robert...
1,807
Short injectors were for van applications. Your "J" code 6.2 in the CUCV uses long injectors.
mcne2026
Kuna, ID
Darn. I read that they were interchangeable, other than space restrictions. Any reason not to run the short ones in the CUCV? They have the same flow rate and pop at the same pressure. Since I already own 4 of them that are almost brand new and can get 4 more for a lot cheaper than 8 long models, I would like to use them, unless there is a specific reason not to.
kennyw
Stones Throw from Reiter, WA
There is a specific reason why they don't work but I forget what it is off of the top of my head. But as an FYI there is one other type of injector, the coarse thread injector used only on 1982 Civilian models.
To top it off there are multiple variations of the long fine thread injectors based on which year and turbo or no turbo.
