Long travel on shifter.
Redpawn
St.Cloud FL
I have an 816 and the transmission shifts seem to be very long. When I shift in to any of the forward throw gears (R-2-4) the shifter will hit the dash and so will your knuckles too. Any of the rear throw shifts (1-3-5) will hit the 4x4 shifter or PTO shifter. I pulled the shift tower off and everything looks in order so is this just how it is or is there something I can do to shorten the shifter throw? I did some searching on here but no luck so if anyone has a link for me that would be great.
US6x4
2,184
Wenatchee, WA
I noticed my M813 had a long throw - not as far as yours but it tightened up a bit when I put a different shifter in because the original shaped spring retainer thing was chipped and cracked. If I were to force my shifter to hit the dash it would crack this part open. The part is sandwiched between a coil spring and a retaining ring.
You can see the part I'm talking about in these pics. Maybe your part is broken also?
Brutacus
201
Marion, AR.
My shifter in my M818 does the same thing. I thought it was normal. I've seen replacement shifters on ebay for around $80 or so. Might be time for a replacement.
