looking for a genset to run 3 phase 200 amps
slash79
29 Palms
I do some part time work for a guy and he is in need of a generator that can put out around 200 amps and 3 phase power to run a plasma cutter. what are my options, and what kind of price range are we looking at? I am in the Charlotte, NC area and am a prior service Marine Motor T mech, so I know a little bit about the green gear. Thanks guys!
wreckerman893
Possum Connoisseur
15,629
2,048
My 10k will nake three phase power as will most military gennys......you just have to switch the wiring aound. If the genny is three phase there will be a schematic on it somewhere that will tell how to change it over.
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
The plasma cutter is pulling 200 amps of 3 phase....Just how frickin big is that plasma cutter???
slash79
29 Palms
i know the cutter will go through over 1.5", from what i have heard, I think the 200 amps is right at startup plus a safety margin, we looked at a 60kw but the guy wanted 5k for it.
Speddmon
Cambridge, Ohio
Better check the cutter a little more closely. The output may be 200 amps, but I have never heard of one with an input anywhere near that high. I am not saying they are not out there, I just have never seen or heard of one.
Kind of like a welder...output may be 200 or 300 amps, but the input may only be 60 or so.
wb1895
17
Lexington NC
I have a MEP-003a 10 kw gen set that I would let you look at/ try out on the "blue wrench" to see if that is what you might need.
I am just North of you on I-85 in Lexington
Westech
CPL
6,104
208
cow farts, Wisconsin
really a good working 60k gen set for 5 grand on a trailer is not all that bad..... look at what you would spend on a 60k civy gen set. prob close to 25 grand or more!
we have one here at work that I use (plz cutter) and I can do 1/4 plate no problem with ez and its only a 120V unit 20 amp INPUT. Like stated above you may want to check that input power again.
I am thinking a 10k might do you fine.
Harleyd315
Denville,New Jersey
I have a plasma cutter here that has a Max cut of 2" steel. It is wired 3 ph with a 60 amp breaker. You can wire it single ph but then the amperage draw jumps up to over 100 amps. 200 amp 3 ph is a lot of power, what make and model cutter are you working with?
derf
13
LA
What brand/model is that plasma cutter? Is your guy scrapping battleships?
200A 3 phase is A LOT of power.
derf
13
LA
A "200 Amp plasma cutter" will usually draw around 100 Amps AC at 208V, 3 phase.
I think anything more powerful than that would step up to higher voltages.
The higher voltages are better for allowing use of smaller gauge wire.
leedawg
10
Napa / CA
If your in 29 palms, San Bernardino county I have a 30 kw set that would probably drive that plasma cutter just fine that id be willing to let ya have. Id even deliver it for you. As every body else here has said 200 amps for a plasma cutter at 3 phase power is an insane amount of power..
derf
13
LA
Wow, a free 30kW gen? Bring that to LA. I'll take it.
