ClockworkSkin
- 0
- 6
- Wilkes, PA
I recently burned through a set of glow plugs in a week. Without getting into the backstory, here is where I'm at.
New set of plugs installed right now. New terminal ends on all 8 wires. The wires are currently disconnected. I want to make sure that everything is good to go with the electrical system before I plug the new set in and start it.
I tested the relay with the leads disconnected and I'm getting 24v on the top and bottom posts of the relay. I had the post with the blue wire connected to ground to test the relay so I could get a good read on my multimeter. I also tested the terminal ends (that plug on the ends of the GPs) and got 24v there. Is this a bad relay? Will I get a different voltage if I hook the terminals up? I'm afraid to test because I cannot afford to burn through these plugs at $70 a set.
