Looking for an M1008 CUCV rear drive shaft
KD
Central Indiana
Hey Guys,
Anybody know where I can find a good rear drive shaft for an M1008 CUCV pickup? I got shorted one from a GL purchase. My fault for not checking...and I knew better.
Loc. central IN.
Thanks.
God Bless our Troops!
KD
Armada
Buick City, MI
If you can't come up with a used one, you could always have one built.
I can give you the contact info of a great place near me if you get to that point.
CCATLETT1984
Saint Clair Shores, MI
pull the driveshaft from a 1ton k30 civilian pickup. It should be fairly easy to find at a junkyard. but your best bet would be to have one made. rear shafts are cheap and it will be perfectly balanced.
rizzo
Port Huron, MI
Re: RE: Looking for an M1008 CUCV rear drive shaft
I agree
acetomatoco
RE: Re: RE: Looking for an M1008 CUCV rear drive shaft
GM part #14067762 with 208 xfer and 14020403 with 205 xfer
1,806
Interesting thought. I wonder if there were more K30s than D30s. Seems like more D30s these days. I know I bought a new K30 in 86 and it was an odd truck to see on the road.
wyliek
Chandler AZ
to save some $$ w/ getting a driveshaft built you can bring an old one in and they will reuse the yokes, slip, flanges, etc I recently the length changed on a shaft I had for about $100...my 2cents
Wylie
KD
Central Indiana
Thanks guys,
I found one off a civi truck, although not as heavy as the original, the truck moves under it's own power now...which is much cooler than towing it around. I like the Paramore deal for a new one, I will check with him and see what he has. Maybe I can catch a snow bird coming back north next spring.
Thanks for all the helpful suggestions.
KD
