Looking for designs for air bag mounts for a bobber with dump bed.
simp5782
Feo, Fuerte y Formal
9,338
Mason, TN
You can use steer axle air lift bags from a FLD120 or kenworth they are in the 800 range for the whole kit from Randy's truck parts
Bags are good for 15k
tobyS
835
IN
A few details.
The block has a 5 degree taper to make the driveshaft be within a degree of parallel to the TC output. I made a drain hole to keep the pocket that the bolt through the spring would collect if not drained.
Trooperrob85
Kentucky
A few details.
Thank you sir that looks awesome!
tobyS
835
IN
Putting that plate on the side of the frame about sheared my thumb off. I added an 11 x 3 x 10' X 1/4" plate and my jack shifted, wedging the plate between the frame, my hand and the tire. Anyway....the plate would help on a dump but it's probably too late for you. Just the area where the rear trunion was attached, had lost more than 50% of its strength from rust where the plate joins, is riveted, on my A3. Look for rust swelling on the frame behind that trunion plate.
