Got a MEP003a W/106 hours
![Very Happy :grin: :grin:](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
and no filters
![Crying :cry: :cry:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Cross referenced to NAPA parts.
Air filter: NAPA FIL 2222
Oil Filter: NAPA 1004 (outer gasket does not work)
Oil Filter Gasket: NAPA 5108 (OD 4.458, ID 4.250, CS 0.125)
Fuel Filter: NAPA 3113 (Gasket included NAPA 5131 works)(must open up the tabs carefully)
Fuel Filter Gasket: NAPA 5131 (OD 3.587, ID 3.317, CS 0.125)
Fuel Strainer: Haven't found a commercial one yet.
00257-0067 BAE SYSTEMS LAND & ARMAMENTS
26611 CATERPILLAR INC.
21621-6 CUMMINS INC
35070 HONEYWELL INTERNATIONAL INC.
9500-0229-2 HONEYWELL INTERNATIONAL INC.
BM49891 LA GARY CO
30554-70-508 LIBBY POWER SYSTEMS LLC
191442H1 NAVISTAR INTL CORP
149-1469 ONAN CORPORATION
4F3 OSHKOSH CORPORATION
FX3 OSHKOSH CORPORATION
752002-01 PUROLATOR FACET INC.
F6X12AT3 ZENITH FUEL SYSTEMS INC
F6X12T3 ZENITH FUEL SYSTEMS INC
Check your fuel pump strainers, mine were clogged. I need to clean out the fuel tank from the triple rinse.
I replaced my missing oil filter spring with a GM 350 engine valve spring. No spring retainer.
I am use the element oil filter until I can machine a custom spin on adapter plate.
Will be replacing the fuel filters with spin on adapters as I collect them, a couple of WIX 24770 bases probably.
Oil and fuel Filters are same for MEP002, parts manual lists a different parts number for the oil filter base but the canister and oil filter group is the same. The oil filter gasket is slightly larger with a OD 4.5, CS 0.125.
