looking for full width beadlocks
1993
Does anyone know where I can get full width beadlocks at a reasonable price?
Other than PCV ones.
Something like this:
Action
1,556
East Tennessee
There is a 2-piece that one half looks like that. The other piece has the runflat part on it. They are easier to install and remove.
1993
I'm guessing that the two piece is what is currently installed on my wheels.
Was looking into the single piece because of the wheel balancing difficulties I've heard about regarding rims with the runflat installed.
But maybe the issues are mostly caused by excessive lubricant sloshing around?
They are difficult to find at a reasonable price. They were used primarily on the early civi trucks before they went to 17". They are still available new but at a cost that makes the tires look cheap. The one piece runflats are cheap so I have been thinking of a way to cut off the runflat part which leaves just the beadlock part. It wouldn`t be an easy job but worth the effort. Maybe with a bandsaw with a course blade or maybe a water jet would do the trick.
Action
1,556
East Tennessee
Kascar has the one pictured above for $408.52. Just make some from PVC. What is wrong with the 1-piece beadlocks that are in your tires?
tobyS
835
IN
Probably has one piece run-flats. Everybody with a HMMWV or M1102 is in need of the same thing (that don't want to run with run-flats). They look just like the 20"x 11" that I have but are 16.5" x ?.
Action
1,556
East Tennessee
i meant to say runbflat / beadlock. I know what they are. I have installed and removed many of them. With the proper tool, you can put one in in under 15 minutes.
tobyS
835
IN
If you have some spare beadlocks for the 16.5", I need some too.
How do you make one from PVC? Is there a size that fits correctly to the HMMWV 16.5" rims?
