Looking for some info so I can diagnose a power problem I'm having in a dodge ram 3500 I think it's the same motor and transmission that was in the AF tugs on the flight line?
Ever once in a while if you back off the fuel when your just driving around you will loose all power no RPMs, no power it's still running but just at a idle. If you kick the accelerator to the floor a couple of times it comes back and be fine for a while. I noticed that it happens a lot more when the overdrive is engaged, and never happens when I 'm applying power.
I'm not sure if it's a transmission problem or a throttle position sensor or something else
Any ides would be helpful
