Looking for interrupt switch
kloppk
3,514
Pepperell, Massachusetts
When you lift the switch UP and hold it up does the green contactor light illuminate?
Does it then go out when you release the switch?
These switch's seldom go bad so I'd suspect the issue with the contactor not closing is due to something else.
kloppk
3,514
If you find the problem IS the switch then....
A potential replacement candidate for the 8906K4519 S5 Interruptor switch is a Honeywell 2TL1-70. They are about $39.
The contact operation of the 2TL1-70 is slightly different than the 8906K4519 so some wires would go to different terminals.
I haven't tried it but it looks like it should work.
To use the 2TL1-70 the terminal mapping would be..
The diode would remain on terminals 2 & 5.
8906K45192TL1-70
13
22
31
46
55
64
Currently available from here ---> Switch
Trick1us
East Rockaway, NY
D
Does not go on at all but if I push it in to test the light goes on
kloppk
3,514
If you do have a meter you'll want to connect the meters negative lead to chassis ground and the positive lead to S5-5.
Start the generator.
1) You should measure ~24 volts DC there. Do you get that reading?
2) Then lift and hold S5 UP. The voltage at S5-5 should now be ~ 0 volts DC. Do you get that reading?
19,755
Has anyone found Interrupt Switch for Washington DC?
Guess we would need several maybe?
Yeah, I know this has nothing to do with the problem (Couldn't help myself)
- but everytime I see that title -
The need to FIND the political interrupt switch gets more and more powerful.
Trick1us
East Rockaway, NY
Nope the light stays out no matter that I do it will go on if I push it in to test it only
Ray70
5,862
West greenwich/RI
This may sound like a odd solution but, it sounds like your K1 is hanging up internally.
If you have already measured things per the TM using a meter, that means you have the top cover off and K1 exposed.
Go in there and tap sharply on K1 with a rubber mallet or something a few times, than fire up the machine and try the circuit interrupt switch again.
I can't count how many I have fixed this way.... and a few others here have done it successfully as well.
If it works you may want to consider opening up the contactor to see if there is come corrosion or something in there causing it to stick.
It's a very simple magnetic solenoid and the mechanical motion of the solenoid pulling down activates an internal switch which illuminates the panel light.
Trick1us
East Rockaway, NY
Thanks I will do that anyone know an electric generator mechanic in New York Long Island area ?????
Light in the Dark
5,922
MA
You probably aren't going to find a shop who will touch one of these sets, simply because they are not commercially available, so no tech would have been trained on them. You are your own mechanic with these machines.
If the rest of us can help you get squared away, we will.
Dewie38
189
Milford Ct
Im in Connecticut, I dont travel but I do have parts.
What contactor do you have in this set, (brand), Contact Industries, or Ametek?
You probably dont have a bad switch you have a bad contactor.
Ametek is known for this issue.
I have several Contact Industries contactors.
