Looking to lift my cucv
cucvdonk
va
Looking to lift my cucv. Being able to only run 50ish is killing me. So any ideas or suggestions for the best lift/tire combo to use. Dont want to go to extreme but need to do something due to having 4.56 gears in this thing.
DesertDutchman
Mojave Desert, CA
A CUCV is just a K2500/3500 platform, so any lift for a 73-86 solid axle GM/Chevy. It's been a while, but I had a 79 K2500 Suburban and 4" and under is just a new set of leaves 94) or leaves front blocks rear. After that, a drop pitman arm/steering linkage comes into play..Then there is the way I set it up..4" lift, 3" body. I had cutout flares and ran 40's EASY...4" will make plenty of roon for 35's....if you're going off road, lose the 16.5' or get beadlock wheels or Staun internal beadlocks....
My 2 cents!!!
acesneights1
22
20
CT
I did 4 inch with 35's . I can run about 65-70. Oddly enough I checked the speedo against my GPS and it is within 2 mph. It almost seems more accurate now.
4x4 Forever
Emerald Shellback
Assuming a M1008,
There are several companies that have the complete kit. If you decide to use blocks, use blocks on the rear only. I personally would use all leaf springs for a lift. Dont forget to get dropped steering arm / possibly shocks / extended brake lines. Here is shortcut for 4" skyjacker lift:
Product Search - Skyjacker
They also have a good lift / tire chart:
http://www.skyjacker.com/image/catalog/pdf/Wheel and Tire Chart.pdf
You can also look through the posts and see what others have done and pick the best for you.
Good Luck!!
cucvdonk
va
Yea the main thing is being able to run 65/70 in the thing. and yea its a m1008. i am looking to use springs in the front and drop hangers in the rear to keep the heavy springs cause i haul alot of stuff. I will prob take all the corner bolts out of the bed to help with flex some. But if can get some input on the best place to get a cheap lift would be helpful.
4bogginchevys
rathdrum idaho
Lift options
Dodge used 3.5-4" lift blocks stock in a lot of trucks, junkyard price 10.00
U-bolts for front/rear w/ center pins 45.00
Drop steering arm new 65.00
brake line extensions at napa 40.00
Junk yard score on front lift springs 40.00
Front driveline rebuild for length(if necessary) 75.00
Getting to work on time going 65.....................Priceless
spink7124
tennessee
I don't think that I would take bolts out of the bed to help with flex...when you get good and bound up these frames will flex!!
If you are handy and comfortable with some light fab, do a homemade shackle flip in the rear using the stock hangers. Might be a bit shady but lots of guys run theirs that way. Search pirate4x4 or Colorado K5 for pics.
For the front you could easily do a junkyard 52" spring swap for next to nothing. Use your stock hangers and move them to fit the spring (again go to pirate4x4 or Colorado K5 for a writeup), a zero rate from DIY4X4 to keep the axle from moving to far forward with the different center pin location, and some junkyard 1/2 ton chevy rear springs and you're set.
If you keep the front axle articulation in check, getting the front driveline lengthened a bit would probably work. When I did my shackle flip in the rear the pinion angle was close to perfect and the driveshaft bolted right in.
Some extended brake lines (I had mine made locally to my specs in rubber for $70 for all three) and longer shocks and you're set.
Another thing is I would pay close attention to an rpm calculator before you make any commitments because larger tires probably won't lower your rpm's as much as you think.
4bogginchevys
rathdrum idaho
I just remembered that a very wise man told me that the u-joints/yokes need to be +/- 5 degrees of the same plane....it's not important that the rear yoke point up toward the transfer, but rather they are parallel! If at all possible of course:razz:
