Looks like I need a fuel shutoff valve - Penny for your thought...
Dixiedog
Atlanta Ga
1985 M998 was running fine then it shut off a couple of times when I took my foot off the fuel pedal to stop or turn. The first two times it happened it cranked right up but the third time it would not restart. (3 strikes and you are out:x)
I have fuel to the fuel filter, from the fuel filter to the shut off valve and from the fuel bypass but no fuel out of the injector pump. Fuel shut off valve is getting 24 volts with power on, 18 volts while turning over the engine attempting to crank it. When power is turned on we do not hear anything from the fuel shutoff valve nor do we feel it click or move in any way.
A buddy of mine has a anti tamper tool set to get the fuel shutoff valve off the injector pump.
Questions 1 - Am I missing something or does everyone think it is the fuel shutoff valve?
Question 2 - If the shutoff valve, any idea on where to get one??
dilvoy
25
San Francisco, Ca.
It could be a weak injector pump not putting out enough fuel pressure at idle to operate the injectors. You could try and increase the idle rpm speed and see if the problem disappears. If it does, it would rule out the shut off valve and then you could start shopping for a new injector pump. It could also be that silly fuel return fitting that has the glass plunger giving you problems, but when it gets stuck closed it usually causes the engine to have super low power output, but you didn't mention that.
