Loose rad fan
Asymair95
50
Tucson, AZ
Was changing my coolant and thermostat today in my 97 1078. Decided I better check the cooling fan for looseness because of the horrible stories I’ve heard on here of fans flying into the rad. I turned the main power switch on, tilted the cab, and grabbed the fan. I was able to wiggle the fan about a 1/16” or less. My question is how much movement is too much?
Suprman
670
Stratford/Connecticut
Wiggle in proper motion or pulling the blade forward play? Is anything loose? Some of the blades are sandwiched between 2 metal plates with rubber between them and the blade in the middle.
Coffey1
493
Gray Court SC
Just do your self a favor and take it apart and remove that rubber and bolt fan blade to hub.
Asymair95
50
Tucson, AZ
Superman,
It wiggles forward to back, but just a little bit, maybe 1/16”
I did have to tighten some of the Allen bolts around the fan when I first got the truck, they had worked themselves loose. Will check them again, but I really haven’t driven it much since then.
Coffey1
493
Gray Court SC
That rubber will rot out and fan will wobble all over the place and when clutch kicks in it can destroy blade and throw it into radiator.
Suprman
670
Yup I’m thinking that should be addressed. The fan blades themselves are pretty stiff so they won’t flex. if the mounting is flexing somewhere its probably not right. And yes on a bad day the fan clutch can decide to toss the blade into your radiator. Seen that happen a few times.
Asymair95
50
Tucson, AZ
From what I’ve read, finding a new style clutch is pretty easy. Finding a fan that fits it though is tough. Has anyone found a vendor selling the new style fan yet?
Coffey1
493
Gray Court SC
It's a easy fix to remove rubber and bolt fan to hub. And has been a reliable fix.
We've done several trucks with no failures.
Coffey1
493
Gray Court SC
The holes are already there on blade and hub all you need are a good grade of bolts and locknuts.
Coffey1
493
Gray Court SC
No the Allen head only bolts the hub
The rubber is the only thing holding the blade due to compression
Asymair95
50
Tucson, AZ
Will the number 31 rubber mount slide over the air fitting on the end, or does all that stuff need to come off?
Can I re-use bolt 37 or do I now need shorter bolts because the rubber mount is gone?
