Lost rpms!
redass73
Greenfield, Indiana
hey fella's I need your help. I changed the "button" in my injector pump this weekend and lost 200 rpms. wont get above 1900 rpm's went from a #27 to a # 10. is that my trouble or could I have messed up the shim stack.
redass73
Greenfield, Indiana
sorry It's early for me..got an 816 with the cummins. my desiel guy told me to remove this cone shaped piece from my IP there is a shim stack[told it governs max rpm's] and a small little 'puck' in there. he said to get one with a smaller number stamped in it. he said the smaller one would give a lillte smoke and a tad better throttle response. it does put out a little black smoke but the revs are gone..
AMGeneral
115
Connelly Springs, NC
If memory serves,you have to add a thicker shim to increase spring pressure on the governer spring to increase your max RPMs,(I could be wrong here).Is a #10 shim thicker than a #27?It's been quite a while since I was in a PT pump.
WillWagner
2,574
Monrovia, Ca.
Add a few more shims. Make sure the snap ring is in the groove.
