Lots of exhaust from crankcase breather
47to70
40
somerset ky
Hi ,
What are the possible causes of lots of exhaust pouring out of the crankcase breather tube? Just had the old gal drug home and think I might have a bad turbo, could that be a cause?..............too hot to touch right now. No oil and water mixing.
thanks for any help.
47to70
40
somerset ky
Yes..............that's what it looks like. What is hard for me to understand is how it came on so sudden. The blow by went from a little to a lot in a 25 mile trip.
FloridaAKM
392
Gainesville, Florida
You heated up the engine & stuff starts to clean up, loosen up & your blowby will increase. My truck will do that & it only has 12,000.0 miles on it. The road tube is on there for a reason, to blow all the oil away from the truck onto the road.
Jeepsinker
444
Dry Creek, Louisiana
It very well could be caused by a worn turbo, but it could also be a worn air compressor, one or more cracked piston rings, cracked or burned piston, etc.
cattlerepairman
3,242
NORTH (Canada)
Well, the good news is that you have always wanted to do the head gasket anyway....right? Just drop the oil pan and you are in business! Trying to cheer you up!
47to70
40
somerset ky
Thanks for the uplifting thought. One can not do the rings with the engine still in the truck........can they? Am having to delay my planes to invade Canada until get her running right again, so sleep well cattlerepairman (LOL).
cattlerepairman
3,242
NORTH (Canada)
Yes, you can. The engine can be in-frame overhauled. The working under the truck part sure sucks, but if you lift the frame up a bit you get even more clearance between front axle and oil pan.
Here is a post from someone who did it: https://www.steelsoldiers.com/showthread.php?78609-in-frame-engine-overhaul
Jeepsinker
444
I would still check the turbo before I pulled the heads off, if you haven't already done so. A turbo can eat it's bearings real fast and put shavings into the oil. Same for crankshaft bearings in the air compressor.
While it likely is your rings, it would be a shame to do all that work because you overlooked something easy.
47to70
40
somerset ky
I pulled the intake pipe off................shaft spun easily and found no endplay..................is that enough? My air compressor is a new old stock put on last year and seems to be working fine.
Jeepsinker
444
That's about all you can do. Now think about pulling the oil pan to have a look before you pull both heads. You could just have one damaged piston with a broken skirt or something that really doesn't make it necessary to pull both heads. Or You can just dive in waist deep, tear it all apart, and replace everything. Totally up to you.
47to70
40
somerset ky
Did not get to the oil pan today, but did look at the bigger chunks that were in my oil. They are non magnetic, smooth on one side, rough on the other. Some are up to 1/2" long and all seem to be just a bit over 1/4" wide, thickest piece is .09. Lots of fines of course, the 1/4 width seems to be the original size. Sorry no pics, maybe can get the wife to post them when she's not mad at me (don't hold your breath). Any guesses?
