swindad2
- 0
- 16
- Franklin, KY
Okay, I posted something similar to this last year. My health has kept me from doing any work to the deuce, so I still haven't diagnosed the problem. The truck starts and runs fine, but when you shut off the engine, there is a loud gurgling noise that seems to be coming from the turbo slobber tube. It sounds a lot like a sink draining. Letting the air pressure off the tanks stops the sound immediately. Now I am seeing what appears to be black oil coming from the drain on the right air tank. I can also hear gurgling, "pinging" sounds coming from the air pack at the same time. No air pressure, no noise. Let it run and build air, same noise. I am also losing brake fluid somewhere, but, as I said, my health hasn't allowed me to get started on it yet. Why would pressure on the air system cause these sounds on the engine? Is there a way the air system could leak into the engine? I know that sounds silly, to me also, but I don't have a clue.
In retrospect, the deuce probably wasn't the best choice from someone with muscular dystrophy (adult onset), but I'm sure my fellow green addicts can understand the "need". I was just hoping I could drive it a while before having anything major break. Thanks. Larry.
