Rifleman
- 2
- 0
- HOT Arizona
Well i have a problem with my low air fail safe warning alarm, the alarm horn does not work at all. Now when you start the truck up with the air tanks empty both the low air warning light and the parking brake light, light up on the dash. If you take off the parking brake the parking brake light turns off and once the air pressure builds up the low air pressure warning light turns off.
Now i pulled the fail safe warning horn and checked the cannon plug to make sure all the pins were making contact and also made sure that the unit had a good ground.
The fail safe warning unit looks brand new and has a date code printed on it, the date printed on the unit is dated around the same time frame as when my truck went through the Red River overhaul process so i think they may have replaced the unit when the truck was overhauled.
Only problem is the horn doesn't work. I tried doing a search on S.S. and came up with alot of leads but none of them helped fix the problem, so what do you guys think the problems is?
I sure don't want to get pulled over for a road side inspection and have the inspector find my low air fail safe alarm not working and getting a fine for it.
