Low air/parking brake buzzer inop but warning lights work
2mtrucks
col. city in
As the title says, buzzer inop but warning lights work correctly and shut off at the appropriate pressure/parking brake disengagement. I always look at the gauges anyway but as annoying as this buzzer is I need to get it working. Is the fix replacing the FSWM or am I missing something here? I have combed through this forum for a couple hours but haven't seen an identical situation. Thanks.
Suprman
665
Stratford/Connecticut
Replace the module. I saw one of the newer type modules where there is a hole in the front and you can see the piezo buzzer someone had intentionally "deactivated" it with a screwdriver or something.
Will
gungearz
northwestern indiana
The buzzer module is bad... went out on mine a year ago and I think it's great being not working and hearing the annoying buzz... I sit and let my truck idle for 5 to 10 minutes before I take off... check all gauges before I put it in gear and go if all is well.
73m819
319
gainesville, ga.
That LOW AIR BUZZER is a saftey item that is REQUIRED to work by law, be DESIGN it is a attention getter.
gungearz
Yup... since I'm the only one in my truck. I will modify it on how I like.... the flag works which what matters but if I had a fleet and let someone else drive my truck... then it's a concern... but to me on my truck... I like it the way it is.... if you want, your more then welcomed to come by and take care of it... I'll supply the beer.... and we'll share some stories....
Rifleman
HOT Arizona
2Mtrucks, i posted this same problem with my truck on the form months ago and never got an answer. When you find out what is wrong with your's let me know because mine has the same problem. I bought a replacement FSWM from another member here and that didn't fix the problem so mine still has the same problem. Now i can see one FSWM being bad but two in a row i just don't think that's my problem now.
juanprado
2,785
Metairie/La (N'awlins)
Artisan did a extensive thread on it.
My lights all go off appropriately: parking brake switch & light works on /off ok, air brake light goes off when pressured (both tank switches appear to be working properly) but the annoying buzzard will not shut off. On box #3 and I can't figure it out.
My research tells me the early models with the temp light were also wired through it.
It seems to be extremely common m939 issue.
I have tried 2 different styles of boxes. a smooth plastic and a ribbed metal. I saw on ebay a 3rd style that was plastic but slightly different shape than mine ( more boxy and angular). It sold before i could make my mind up to dump more money on it. :-(
For now, mine is also unplugged till a solution can be found.
Suprman
665
On one truck I had the buzzer would buzz when I put the light switch in blackout mode. Turned out to be a bad ground on the left front blinker housing. I re-grounded all the lights on the truck. I sanded spots and added ground wires and bolted them down with lock washers then painted over them. Problem solved. The lights were still coming on just a little dimmer than they should have been. They were finding a ground somehow thru the parking light circuit. I finally figured it out when I had the blinkers on and the left front parking light was blinking with the blinker.
2mtrucks
col. city in
I got lucky...the FSCM has a small hole about 1/8 inch or so and all sound emanates from that hole (at least on my A1).I was looking at another truck with a working low air alarm and if I covered the opening on the FSCM tightly with my finger it went silent. So today I got a dental pick and gently scraped the opening and it began working. Obviously there was some obstruction...insect residue, mud or maybe a manufacturing defect...not sure what it was.
frioman
Houston/TX
The TM states, "WARNING ALARM BUZZER is located above left cowl vent." My truck is 10 miles away at the moment or I would simply go look, but I'm assuming they're talking about the vent inside the cab near the driver's left leg. Is this correct? Thank you.
marchplumber
2,555
Peoria, Illinois
My buzzes alright, but darn parking brake light is inop most of the time, low air pressure light almost ALL of the time, except when very cold. Does that make sense to anyone?
God bless,
Tony
juanprado
2,785
God bless,
Tonh
I believe you have multiple problems. The parking brake light is a small flat metal switch in the parking brake handle assembly. Other problem could be a low air pressure switch (2 of them) , the box or ground issue.
