Low BOy Id
rumplecat
221
North West Arkansas
I found this trailer on the side of a country road in the Mississippi delta, it is in pretty bad shape and it looks like the dove tail on it broke off and they just threw it up on the trailer. I noticed it has a couple of guide rollers up front , it seems like a pretty stout trailer. Worth saving?
NDT
6,486
Camp Wood/LC, TX
That is the most rode hard, put up wet M172 25 tonner I have ever seen. For what it will take to straighten that one up, buy a nice one from GL for 3 grand. The deck over the gooseneck was added by a civilian.
123mack
11
Jemison, AL
Depends on several things. Looks like it's on the right of way, so whatever is the law in Arkansas on abandoned vehicles would determine ownership. Once that's settled it would be a matter of how much work and money you would be willing to put into it.
Chief_919
100
Western NC
As far gone as that one is, best bet for it is drag it to the scrapyard while scrap is up.
Should swing about $1200+ in scrap for it.
Then buy one from GL.
porkysplace
1,493
mid- michigan
that looks like a prime canidate for a big shear I have seen trailers was not twisted that bad side loading excavators regularly it's worth its weight in scrap
Irv
Noxon, MT
Could be either the M172 (15 ton) or M172A1 (25 ton). The only difference I can find is the axles, and you can't tell that unless you look at the data plate or look for the "Arsenal Grade Axle" marking on the axles. The landing legs are missing, too. Scrap. Irv
