Low pressure at the horn
Rooster828
Minnesota
My horns have insufficient air pressure , curious if there’s a common issue where the air lines get plugged. I’ve been looking for a schematic to see which tank runs the horn and everything in between.
simp5782
Feo, Fuerte y Formal
9,338
Mason, TN
Do your wipers work slowly? If so you have a sticking pressure protection valve on the wet tank. Or worst case a collapsed cotton jacket hose from the frame rail up the firewall.
Rooster828
Minnesota
No the wipers function normally, the horns always had just a weak shreak sound, so I went to add a larger air horn and discovered there just wasn’t much pressure being produced
simp5782
9,338
Mason, TN
QUOTE="Rooster828, post: 2284813, member: 93351"]
[/QUOTE]
Pull the fitting from the horn and get an air fitting to an air gauge if you think low pressure.
The governor feeds that horn on a t line so basically if your governor is causing your air dryer to purge like normal then there is 120psi going to that horn
Rooster828
Minnesota
L
[/QUOTE]
Figured it out. Air pressure was fine. Solenoid was not opening completely.
