forest522
- 3
- 18
- Bernalillo, New Mexico
Good day everyone.
Long time reader and admirer of this site. Thanks to the common issues discussed and resolved here I have had this m1009 on the road for over 8 years including a move from PNW to the SW towing belongings in an m116 trailer and more recently a trip to VA and back to ABQ. She has been on countless trips to the mountains.
Side note to a recent thread - weak power has always been an issue on long grades, an extensive fuel system inspection, clean up, spin on mod and replacing of fuel tank and sending unit have "helped" to resolve that issue. Still, I live at 5500 feet elevation and travel into and around the 7000s frequently.
I digress...to say the least, I love this thing and keeping her running well.
After the recent trip back east and back, I decided to go with a Vintage Air install. And, "since I was there" I did the spin on filter, replaced the fuel pump and inspected, cleaned and replaced/upgraded wiring in areas needed.
I also rebuilt the alternator using the thread directions on this site. A great thread by the way. Thank you.
After buttoning everything up and checking/rechecking my work over the past several weekends, I started her up. To my surprise after all that work, she started right up after just a few of the priming cycles lined out in the tech manual. Easiest I have ever done after filter replacements, etc.
Here begins the diagnosis of a new problem (yay).
Symptoms...low voltage indicated on the meter and as measured from the pos terminal in the rear of the alternator - 11.9 - 12.2 volts.
No dash lights on the left side (speedometer) and no ALT light when turning engine on.
Work done so far: Removed fuse block, engine side, cleaned off all connections. Fiddled with the connector on the rear of the instrument panel...no improvement. Checked all fuses. Removed, examined and replaced Alternator...looks like it should...
So my thoughts are this: Replace the printed circuit ($60 LMC), rebuild the alternator again.
Am I missing anything? Thank you for reading this long post!
