vtach
- 5
- 18
- North Dallas, TX
I have a deuce that the voltage meter seems to drop over time. One time it was no longer reading and my headlights were very dim. Found a small wire that was pinched on the alternator cap (was ground out and sparking). I repaired it, charged the batteries and all was good for a few days. Now the vo;t gauge is droping again.
I hooked a volt meter up to the alternator and both the small and large wire are putting out 23.7 volts at 1100 rpm. The truck's volt meter that is reading yellow shows 23.7 volts, and 23.4 with all the lights on. Is this normal?
There are some stray wires under the dash that to be taken care of too.
