Lug nut and spare tire crank sizes
Nonotagain
41
Parkville, MD
I'm about to recover a M1061 trailer that has a flat tire and needs to be removed and replaced prior to the trip home.
Does anyone know what size are the lug nuts and what size socket/handle fits the spare tire crank? The lugs appear to be the same size as the Deuce lugs, can anyone confirm?
If this were a short distance recovery, I'd just chain the axle up and charge on, but this trailer is going to my folks house a couple of miles away and has a Ditchwhich on top.
Thanks for any help.
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
I will double check mine tomorrow, but the lug's should be 1 1/2, same as deuce. Spare tire crank uses the same crank as the leveling jacks, they should be stored underneath, next to the jacks, and one at the back, next to spare. I think they are 1 inch square.
Dennis
Nonotagain
41
Parkville, MD
Thank you sir!
I normally don't carry my 1" socket set and breaker bar with me due to the weight, so if I only have to bring a couple of sockets, this will lighten up the load quite a bit.
