luverne brush guard dimension ?
whistlepig
big branch tn
lvn3.jpgI'm fabbing a luverne style brush guard and was wondering if someone knew dimension A and what the approximate radius of bend B is ? I can't find any info online and don't have access to measure one in person. Thanks for any help .
cwc
147
Sweeden, KY
Hi whistlepig, I happen to have one in the backyard. The A dimension is 13-9/16". The curved portions all appear to have the same radius, and are a good match to the rim of a quart-sized paint mixing cup, with 4-3/8" diameter. The guard is made from 2 x 3/8" flat bar. Here are some additional pics, including some that show the size of the expanded metal. Hope they help you - or somebody in the future.
How about posting a pic when you get it done. Also, how are you going to bend the flat-bar?
13.5625 height.jpg Qt paint cup.jpg 4.375 diameter.jpg Left side horizontal dims.jpg Left main upright location.jpg
Right side horizontal dims.jpg Right side vertical dims.jpg expanded metal horiz.jpg expanded metal vert.jpg
cwc
whistlepig
big branch tn
CWC ,You are awesome! Thanks for taking time to help. Will post pics when complete. May make a die and bend with a press or heat and bend in a jig ,probably play with both methods.
cwc
147
Sweeden, KY
Looks good! How did you make the bends?
MattNC
270
Raleigh, NC
So I started building my own brush guard off dimensions shown on this thread. I did the bends with a propane forge and a easy jig I made with angle iron and a 4” round piece of steel. I just have it tack welded for now. The mount I made from 3” tube cutting it open into a bracket. I’ll post progress as I make it.
58CA0DA8-BAA3-4D03-BFCD-D8A9EA5E8A84.jpg204CBE1C-2394-431B-AD6B-6C13429BD62D.jpg22E858C8-7A60-4485-8076-F1A42D0E6982.jpg
MattNC
270
Raleigh, NC
I can take some measurements in the final height. It depends on the bumper you have. I did some customizing as well to get it the way I wanted. I used 3/8 thick bar as described here and the uprights I used 2” square 3/16 thickness. The brackets were 3” square tube I cut a side off of. I ordered 3/16 thickness for that and they delivered 1/8. Should be fine but I may go back and remake them someday with the heavier material. I used 1/2” tractor pins for the top connections and 1/2” grade 8 bolts for the bottom with washers as spacers and to allow it to pivot easily. I’ll take pics tonight.
MattNC
270
Raleigh, NC
So I bought 30’ of flat bar and have maybe 5’ left as I built it. The uprights were about 22” each. I used 1.5’ of 3” tube for the brackets. I bought but didn’t use expanded plate for screen. I decided not to add it. Here’s some final pics.
i might decide to redo the brackets slightly thicker someday as they are 1/8” steel (I ordered 3/16 or 1/4 but they delivered 1/8). Otherwise I’m happy and it doesn’t rattle.
TOBASH
3,246
Brooklyn, NY
What radius did you use at the corners?
Super nice looking unit!
MattNC
270
Raleigh, NC
Thanks. I bent it around a 4” in diameter steel round, so a 2” radius. Couldn’t get any shop to respond to my request to bend it so I went with using a little propane forge I have and this jig I made with angle iron, rebar welded on to help keep it from rolling, and a 4” off cut borrowed from a neighbor and clamped on. I just heated it, bent it which once red hot was easy, and then checked it with a square. I think an oxy torch with a rosebud tip would work well. Just heat a 4” section so the rest stays straight
TOM R
81
sewell n.j.
Can someone give me the correct hole locations on th bottom of the uprights from an original
How far is center of the bottom mount hole from bottom and how far back from the face
