hot rod deuce
- 0
- 0
- Kasota, Mn
All right this is my next plan as soon as the cummins is done and i run 100 or so miles on it. I have a bunch of 10" long travel air bags and im going to use one on each axle to lift a rear. (rear or center axle) then add a steering axle to the center. When i go for a long cruse i can lift the center axle and gain wheel base for a better ride. and the air bag will also have a portion of the weight on in to that will be jsut like adding air ride when one axle is up. or when im trying to get through the wendys drive through i can lift up the rear and use the center steer axle to turn on a dime. Also a helping factor is that when i spread my axles for the little bitty 16.00's the center one got closer to the front and that wheel base is shorter than my reg. cab long box pick up so if it steers too the thing has got to turn on a dime.
What do you think?
What do you think?
