m-35 studebaker arctic test truck
eme411
pefferlaw ontario
I've just started working on a arctic test M-35 gasser and I need photos and info, truck is still very complete with door markings, USA number , gas heaters, hard top , I need to find info on the cargo cover and rear man door and wall , I'll post some photos as soon as I can , hope someone out there can help , I've already tried e-mailing David Doyle , no response , so I need some help,
regards Frank
cbvet
20
Northwest (Knox) Indiana
The cargo cover on mine was simply 2 layers of heavy canvas with fiberglass insulation in between, attached to the lower edge of the bed with metal strips & bolts all around. Took it off because couldn't roll sides up, then found out it was rotted anyway.
Also had the plexiglass windows in the sides. Rear wall was just plywood with a door in it. Floor is plywood over foam insulation. Still has multifuel heater in bed.
