M-35A2 wiring
steelandcanvas
86
Southwestern Idaho
First, check the connections on the flasher box especially the ground connection . Second, check the cable connector to the turn signal unit on the steering column. Maybe I should have made this the first one, did you check the lamps at the turn/stop/running light units? Are you familiar with the operation of the light switch? Oh, and by the way, welcome to the looney-bin!
