m 925 winch operation question
rsramey
augusta,wva.
I have an M925 with winch and when you put trans. in neutral to engage the winch and try to put it back in gear to let the wheels help a little it disengages the winch. Is this normal operation for these vehicles not for the winch and wheels to work at the same time?
74M35A2
329
Livonia, MI
My 925A2 was stuck in 4' of mud, and the winch sucked it right out, didn't even need to snatch double the line. This was all in neutral. I was also wondering if the drive wheels can help out, but I forgot to check while doing so, and just did it all in neutral.
Reminder: Don't operate the hydraulic pump over 1800rpm as stated in the manual. I did not know this, and I held the pedal on the floor at about 2300rpm to wind the winch and get out, and now I have a medium size hydro leak at the direction control valve. If you compare the inlet and return hydraulic line sizes, you can see why they want you to limit to RPM (flow). The hydraulic pump can out-flow the control valve and the pressure relief within it.
Also I think you may have your PTO engagement procedure backwards. Trans goes into Drive to engage PTO (pump), then put trans into Neutral to spin the PTO (pump). It is opposite of how you think it should work, because it is an automatic and the gear case contents are all at a standstill when in Drive when not moving.
Wildchild467
57
Milford / Michigan
Yup, I was there. I don't think it was 4 feet, but it was nasty mud. :)
rhurey
14
Bothell, WA
Won't the PTO still spin while the wheels are slipping? If you're stuck and not making progress because you can't get enough traction, you'd still have a spinning PTO right?
Or is it not fast enough to pump an effective amount of fluid?
FASTNOVA
146
Los Angeles,Ca
Not sure if that will work or not. When I was stuck the way out of it was to winch in then put in drive to go forward a little then back to neutral then winch in and repeat.
74M35A2
329
Livonia, MI
Well Cleatus, those are 48" tires, and it is **** near the top of the intermediate axle tire, so.......
I think the PTO (pump) should spin if the trans is in drive and the truck is driving forward......think, not sure. Will need to get stuck again and confirm, or, lay under the truck and have a friend drive over you while you watch the PTO/pump driveshaft.
timntrucks
119
Ponchatoula LA
not wanting to steal this trend and i am open to learn all i can learn .. i just bought a 925a2 and will need to read some tms.. i plan on putting on a rewinder.. any problems you guys can see i would have. i will need to rewind the cable up backwards from the way it is now. also with you telling how strong the winch is should i worry about putting in a snatch block on the truck?
73m819
320
gainesville, ga.
The -10 has a bit about NOT having the trans in gear when using the self-recovery winch, sometimes a change (809 to 939) is NOT a upgrade.
monkster
Mt.Vernon, IN
One hint. While in D and tring to engage the PTO and won,t go in gear, let the truck roll a little and the lever drops in gear. I have wondered if this was a short comimg, not leting the wheels help the winch. Sounds like its not. I also like the 1800 rpm and below, missed that in the manuel.
98G
Former SSG
4,418
Um, if you're stuck enough to need the winch and the driveline, you're probably too stuck to let it roll a little....
Being able to use the driveline and the winch together is a powerful argument in favor of the warn winch for self recovery. (And duty cycle is a big argument against it)
Gunzy
66
Roy, Utah
I would have to see a pic of the way your cable is currently wrapped on you winch to be sure, but if the winch is spooled backwards it will reel up the cable but NOT pull any torque. I know as mine was backwards and couldn't pull a small tree out of the ground and after rewinding it the correct way it can drag a 12K lbs F350 wrecker backwards while in park with the E brake on. We had to respool Mtnsnow's winch and just picked up an M925A2 that will need to be respooled as it is also backwards. Got to love newbie privates in the motor pools.
M2Guy
Canton, Ohio
It has been my experience that as a general rule of thumb most applications involving a pto and hydraulic pump, have the pto gear ratio/pump flow output for whatever is being driven, with an engine rpm in the 1,500 to 1,800 rpm range so that's good advise for most hydraulic systems.
