Ras1
- 41
- 18
- Rockford, illinois
Just got my new m gator fired up for the first time, started right up!
The engine idles great, some black smoke on acceleration, engine starts shaking and clunking at about 5mph.
Engine is a yanmar diesel .
I only test ran for about 5 mins. The injector on far passenger side is wet, and bubbles are coming from where it meets the head. It does not appear to be loose, or ever even removed from the factory, ie bubba has been messing with it. Clear return lines look good. I was hoping for a loose line or broken return but when I saw bubbles from cylinder pressure I think problem is more serious.
My question to gator folks is any thoughts on injectors or gaskets? I have changed injectors on humvees, they have a copper gasket. Before I tear into it I'm hoping someone has run across this. Bad head? Cracked injector?
Best place to buy injectors and engine parts?
Also looking for original m gator bed. Bubba changed mine out with a civilian one.
Thanks! Dave
Thanks! Dave
