m1008 charging issues
cooterfrmhazzard
ellicott city maryland
after a week of research thru treads and going over the tm's i am stumpped and dont know what else to do. i have two brand new batteries, ps alt has been rebuilt, belts are tight, fusible links have been checked. when i start the truck, the needle on gage will not come into the green area, it sits right on the line between green and yellow. i checked both alts when running to see that the ds is putting out btw 12-14 and the ps putting out btw 24-26, i dont know what else to do, beggining to get frustrating seeing as this is my daily driver and plow truck, any response/help would be greatly appreciated.
notsosanestan
NNJ
do both of the gen lights come on when you first turn the key? my gen 1 light was loose and it wont charge unless its working mine was doing the same thing sitting between the yellow and green but now wont start after its warmed up
hobie237
Newark, DE
Have you experienced any other symptoms and/or performed any diagnostics beyond what the stock gauge says? Added resistance in that circuit from years of crud formation could easily show an improper reading. Just get a voltmeter and check it at the batteries with the truck running and you'll know whether you have a problem or whether you're just throwing parts at the truck.
scottodog
nj
Check the voltage on the drivers side alt meter ground to truck ground meter positive to power stud it should be around 14 volts then check the pass side meter ground to the positive stud on the alt located closest to the center of the engine (wire from the drivers side alt 12 volt) and the meter positive to the stud on the alt further out with the large and small wire going to it(24 volt stud). Doing the test this way will give you how much voltage this alt is putting out it should be also 14 doing it this way. This will give you correct running voltage from both alts.
burbn10
Lake Villa, IL
My M1008 does the same thing with the volt meter until the glow plug controller switches off. It sits in the yellow a while then it climbs into the middle of the green once the relay disengages.
