M1008 front axle question
reaper556
HOCKLEY, TX
Sorry if this isn't the exact thread where this question should go. Im going next weekend to pick up my first m1008, could someone tell me the width of the front axle hub tip to hub tip. My friend is going to loan me a trailer to pick it up with but im concerned about it fitting on the trailer since it has pipe sides about a foot high around it and I figure down low the hubs will be the widest portion of the truck
reaper556
HOCKLEY, TX
81.2 is the military dimension, I wouldn't think they would give that measurement to then have an additional "bit" sticking out.
I suppose you are correct, I was putting a bit too much thought into that dimension .:doh: With the mirrors folded the hubs would be the widest portion of the truck. Thanks [thumbzup]
nyoffroad
687
Rochester NY
Take along a couple of 2"x8" as long as the trailer, that would 'lift' the truck 1.5" if you need the extra height. Good luck and chain it down well!
