M1008 front spring replacement help
gotzskillz
Raleigh, NC
Hey all,
So I recently bought a M1008 and am working on getting it reliably drivable. It has death wobble so ill be rebuilding the kin pins, steering components, and replacing the shocks. Another problem it has is that the driver side spring is sagging severely causing the truck to lean to the drivers front. So obviously since ill have most of the front end apart i figured id go ahead and replace the springs.
Ive been doing a good bit of research looking for replacement springs and other than using someones throwaways, I found these:
https://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=1449
The only downside, aside from price, is that they are 2 3/4" wide where as the originals are 3". Would this be a problem and/or does anyone have any other recommendations for replacement?
Thanks,
360
southern ca
I purchased a complete set of springs (front and rear) for my 1009 from SD Truck Springs and have the front installed so far. Huge improvement and pick the old girl up and bit and leveled her out. I wish I could tell you on the width, I don't remember honestly and am not near the truck. I ended up going with the heavier spring option though as I run a plow on my m1009 and a heavy bumper with 12k warn winch.
I think that's the best price your going to see, I couldn't find anyone with cheaper prices when I did my swap especially when you consider shipping. Do yourself a favor add it all up on the website with shipping then call and ask if they can help you out a little and they likely will. I would advise not being in a rush either, I had one of my rear springs lost in transit with UPS if you can believe that.
Over all I would use SD springs again, I had a set of custom made springs at ATLAS springs out of SoCal and it was a miserable experience. Repeat trips, wrong weight rating, poor customer service, etc. If I ever put anymore springs on one of our trucks I will look at SD first.
ehuppert
138
Upstate NY
Also check ATS springs. They're located in Pa and ship quickly. I use then for the shop I'm at and they're knowledgeable and fairly priced. And they stand behind their products!
Eric
blueblaze
Chapleau, Ontario
You have to measure the spring pack width right where they mount on the axle perch. Last time I remember they are 2.5". Its a very big misconception because people measure at the end of the spring pack and they assume they have 3" wide springs.
