trooper632
- 5
- 18
- Utopia, TX
Newly acquired M1008 has a problem, it is blowing the fuse for the charging system in the fuse box. Its the bottom fuse marked 28V, I have tried fuses from 10amp to 30 amp, keeps blowing them as soon as the key is turned on. Truck starts and runs perfect but the volt gauge doesn't work, that fuse runs the charging system. I don't see any of the fusable links blown anywhere and I removed the fuse box because the place where the fuse goes looks burnt but after looking at it I don't see that it would cause any problems, but im at a loss, any suggestions?
