AFC1
- 0
- 0
- Central Jersey
Hi all- I have a 1986 M1008 with 89,966 miles on it. Never had any wiring/starting issues with it until now. Original 24V wiring has not been messed with. In October 2013 with exactly 80,000 miles on it I totally restored the truck- all new sheet metal, SM465/NP205 conversion, injection & water pumps, put a 1973 nose on it- spared no expense, did everything. Put almost 10,000 miles on it since then, has never seen the rain. Now I am experiencing a glow plug issue. Noticed that glow plugs would not activate every once in awhile when the key was turned on. Wait light did not illuminate and truck would not start. By cycling key on/off several times, Wait light would eventually illuminate and truck would start. It got worse, (more key cycling required) and happened more frequently, so I decided to do something about it. Put new card in it along with new ST-85 relay- no difference. Discovered bad temp sensor behind driver head. (New sensor had continuity at dead cold and old sensor was off the charts). Reinstalled original glow plug card, but left new relay. Installed new sensor and Wait light illuminated on the first try and truck fired right up. Was really happy. Waited for good weather and took the truck out today. Started truck with no problem first thing in the morning, about 5 miles from home while driving 50 mph Wait light briefly flickered. This has done this previously and I figured my original problem was still there. Truck sat inside the garage at my work all day and sure enough come 4:00- truck would not start and Wait light never came on. Had to cycle key twice and light finally came on. Anybody have this issue that could save me some time and point me in the right direction? Also, dont know if this is related but....there are 3 M1008s in the family and this truck has never cycled the glow plugs like the others do where the voltmeter dropped and you could hear the relay clicking on and off. Never thought much of it because the truck has never let me down once since purchasing it in 2009- until now. Sorry for the long post, but wanted to give as much info as possible to try and sort this out. Any info is greatly appreciated- thanks for your time!
