jimmyjimwas
- 9
- 8
- pittsburgh/pa
Hi, One great site and members...
Ok have done some research on this, and my question is IF it is the fuel pressure switch which i always read about allowing air into the fuel can you just replace the o ring or what ever the seal is. Or is it one unit . I have not removed the switch,.I also will check replace the fuel lines from the fuel housing.Now also are these fuel lines standard fuel lines sold at the auto parts or are there better ones to get?
Is there anything else i should look at to solve the problem.. Great if you can help
The m1008 starts great when you drive it daily...
