burbn10
- 0
- 0
- Lake Villa, IL
I just wanted to bring to light a problem for pre-1985 M1008/09 owners. GM issued a recall for these vehicles and the civvy counterparts because of faulty oil cooler lines. I just found this out today when I went down to my garage and noticed the pool of oil on the floor. Thankfully, the line didn't go when I was driving. I did some research and found that there is actually a still-active recall for this issue. Here is the information:
Number:85C14Section:6 & 6ADate:August, 1985PRODUCT CAMPAIGN 85C14 ENGINE OIL COOLER LINES MAY FAIL
1985 C/K/G/P MODEL LIGHT DUTY TRUCKS EQUIPPED WITH AN ENGINE OIL COOLER TO:ALL CHEVROLET DEALERS
General Motors has determined that some 1985 C/K/G/P Light Duty trucks equipped with a gasoline engine or a 6.2L diesel engine that have an engine oil cooler, RPO KC4, may experience failure of the engine oil cooler hose/hoses. During normal operation the hoses may burst, resulting in a rapid engine oil loss which could result in internal engine damage.
To prevent the possibility of this condition ocurring, involved vehicles must be inspected for suspect oil cooler lines and replacement lines installed if necessary.
OWNER NOTIFICATION
Owners will be notified of this campaign on their vehicles by Chevrolet Motor Division (see copy of Owner Letter included with this bulletin).
DEALER CAMPAIGN RESPONSIBILITY
Dealers are to service all vehicles subject to this campaign at no charge to owners, regardless of mileage, age of vehicle, or ownership, from this time forward.
Whenever a vehicle subject to this campaign is taken into your new or used vehicle inventory, or it is in your dealership for service in the future you should take the steps necessary to be sure the campaign correction has been made before reselling or releasing the vehicle.
Owners of vehicles recently sold from your new vehicle inventory are to be contacted by the dealer, and arrangements made to make the required modification according to instructions contained in this bulletin.
Inspect both engine oil cooler lines for manufacturing date code (reference the 1985 Light Duty Truck Service Manual, ST-330-85, for cooler line location). Lines marked with a date code of 2654, as shown in Figure No. 1, must be replaced. In addition, replace the cooler line if the date code cannot be read or if the date code does not appear on the hose section of the line.
Lines with identification numbers other than above are OK and are not to be replaced.
Naturally, it will cost me more to get my disabled M1008 to the dealership for repair than it will be for parts, so I am going to fix mine myself, but I figured I would share this with everyone else. I got new lines from NAPA for $33 each.
OWNER NOTIFICATION
