Thomas_G
- 7
- 8
- Houston, TX
I have a M1008 with just over 14,000 miles (Ft. Hood TX). The issue i have is one day it ran fine, next no start, just crank and crank.
Checked following:
1. Confirmed 12 volts going to glow plugs (has been converted to push button)
2. Installed new glow plugs
3. Rebuilt alternators
4. New high torque starter
5. Batteries are new
6. New Coolant Temp Sensor Shorting Solenoid
7. Removed oil fill tube, turned engine over by dampener (15/16 socket) and pump gear turned.
8. New lift pump installed
9. Primed fuel filter
10. Pulled rubber line at lift pump and had fuel in line.
Only thing i am thinking the shut off solenoid maybe bad? i can't remember if you need to hear that click on the I.P when key turned in the "on" position. I needed the starter and alternators rebuilt cause they where original and worn out.
I found a quick and easy way i used to prime the fuel system, I used a Caterpillar 1U-5718 Lube sample pump (bottle attached) and removed the bleed cap and put my finger on the hole while pulling a vaccum, i filled the bottle up with fuel and then installed bleed cap on filter housing instead of draining batteries or wearing starter.
Any ideas?
Checked following:
Any ideas?
