Rebelpride
- 5
- 0
- Thomasville, NC
I have been in the process of lifting my M1008 and the only thing left is to install the pass. side rear shock. My problem: the Skyjacker shock that I had been trying to install would not clear the axle. I tried to beat the mount back towards the rear but only ended up cracking a weld. Took the one rear shock that I had assembled and tried to install it on the drivers side mount and tada it went right in place like its supposed to. It appears that G.I. Joe may have backed over something and pushed my mount in.
My question is how do you fix it? Beat it back and reweld (can you weld on an axle w/o cracking/weakening issues)? Heat it up and gently pull it back to the stock location? Or carefully cut it off and reweld it?
