M1008 rear shocks repositioning
Enforced_Leo44
Parma, Italy
Hi everyone,
My rear shocks are shot, so I took them off, measured them and bought a equivalent lenght/travel from Bilstein, 5125 series (yet to install for reasons that I'm about to explain). My truck is not stock, and has been so for the past 3-4 owners.
Bad news is: previous owner decided to mangle up the shocks mounting/system and mess everything up, my shocks sit outside of the leaf springs instead of inside, and with the eyelets of the shocks facing the wrong direction, meaning the shocks can pivot left and right but not back and forth, which I guess is what demolished my current shocks because of binding.
Now, since the original mounting points and brackets are long gone (and since I'm in Italy I can't seem to find them without spending upwards of 1k$ a pair), I was thinking about re-repositioning the shocks to what I think is a better non-stock system
Like this (picture for reference, it's not my truck nor it's a CUCV/Squarebody, just to give an idea):
By putting a cross member above the axle of course, since I don't think there's one there from factory
I have ways of fabricating the required brackets, the questions are:
Is this a safe way of doing things?
Am I going to mess something that might lead to a catastrophic outcome?
In the stock system, one shock is angled backward and one forward, does that serve a precise function that might screw up the drivability of the truck if removed?
Thanks in advance for any advice
Leo
Enforced_Leo44
Parma, Italy
Or, alternatively (since it would be quite the job because the exhaust is in the way) does anybody know where I could get a replacement for said upper mount? Maybe even from a different vehicle, I could adapt them to my need. I looked online and F-250/350 rear upper shock mount go for relatively cheap, would those work?
nyoffroad
727
Rochester NY
I've made my own shock mounts a few times out of flat stock about 5/16" thick, not hard to do. I did learn that after drilling and before welding to make and bolt the pieces together with a spacer the size of the shock.
Mounting them in the center like the pic would put quite the strain on the crossmember, no idea how it would handle.
