M1008 Rear Spring Hangers Bent
red450IH
Nashville, TN
The rear axle rear spring hangers (where the shackle is) are bent! I have pulled the bed to paint the frame and did not notice this until the bed was off. It's bad enough that it has made the spring bushings wear at a very noticeable angle. I haven't figured out how to post photos but hope to soon.
Are these the same as a 1/2 or 3/4 Ton? Any ideas where I can find these? I'm assuming I'll have to drill out the rivets and go back with bolts?
Keith
acmunro
Reynoldsville,PA
I've never had to replace them because they were bent, but I have because of rust. You are correct on the process. I would use some good Grade 8 bolts. If you cannot find the hangers closer to you. I could round up a good used set.
acmunro
Reynoldsville,PA
I can't say for sure. I am too far away from home to go out and look. I know the spring center to center is different from the 1 ton to the lighter trucks. I am not sure if the frame itself is narrower or if the spring hangers are somehow different. Hopefully someone will chime in.
