KansasBobcat
- 8
- 18
- San Antonio, TX
My M1008 came with the rifle barrel mounts removed. A local club member found a M1008 that was being parted out. When I drilled out the pop rivets I did not notice that there was any difference between right and left. Well, there is a difference which I discovered after installing. I used rivnuts instead of pop rivets so it was no big deal to switch. The difference is the angle of the bracket for the handguard. They will only work one way. I continue to learn...
