M1008 vehicle wheel corner weights
deank
692
Inverness, Florida
You might try to see if your local landfill or recycling company has scales they will let you use. I have done that with my RV at a local recycling place.
JTRUCKJMC
W.P.B., FL
We have a whole vehicle scale at work that will do a semi, however I am trying to weigh each corner. If I only knew a DOT or Trooper....
Bob H
167
Some race cars guys have scales.
The data tag on the door shows location of center of gravity, with that info a little math will get you front & rear weights on the axles. Right front probably has more than left front as the batteries are on the right , fuel tank on left may balance that out a little.
