M1008; will the HUMWV 8 socket wheels fit the M1008?
rattler1982
Donna, TX
Looking to fit my CUCV with a bigger set of tires for beach n hunting fun. Will the regular HUMWV wheels and tires fit a CUCV M1008 with no changes to the body?
Warthog
242
OKC, OK
No.
You will need 2" spacers for the rims and at least a fender trim depending on how bad your springs are sagging. Most guys end up with a 4" lift
rwb
Fruitvale bc cnd
Hmmwv wheels on m1008
I'm looking at putting on hmmwv wheel on my m1008 , does any one know how they fit on the front do you need spacers or not
fitz
13
Mass
I've read that you can run the dually hubs in the front to eliminate the need for spacers.
Chaski
56
Burney/CA
There are lots of options that a lot folks have done on the forum. Personally I have re-centered a couple sets of wheels. The stamped centers make the wheels about 3.5" offset. Flat centers set in as far as possible result in 5" ish backspacing. Stock HMMWV wheels are about 7" backspacing. With low backspacing comes large scrub radius in the front. The outside of your tires travel in a larger arc and will require more fender trimming with a low offset. I am really quite pleased with 5" backspacing, they are tucked in nicely and I got away with less trimming than my buddy that has the 3.5" stamped center. 2" steel spacers with stock wheels is a pretty clean solution, or re-centered wheels with flat centers. Just be aware that stamped centers, or dually hubs with stock HMMWV wheels will require major fender surgery.
