M1008 with Behr Paint Question
Vet89
Cedar Rapids, Iowa
I started painting my truck to get it back to OD green and read these posts:
http://www.steelsoldiers.com/paint-bodywork/66973-exterior-latex-acrylic-house-paints.html
http://www.steelsoldiers.com/paint-bodywork/65478-note-latex-house-paints.html
Great Info!
I used a Rustoleum spray paint and did the grill and bumper. After a couple days of cure, I took it to the car wash and had it hit with the sprayer - nothing came off!
I then started with the Behr paint and olive drab code used in the links above.
I brushed the first coat and rolled the 2nd. Looks great, but this morning, I rubbed the paint gently with my fingertips and got green fingers.
Is it that the paint needs more time to cure or should I put on a clear-coat of some kind?
topgun217
The Northern Border of Ohio
I'm gonna bump this thread. I'm wanting to use the behr paint over existing carc and was wondering......can I just spray the behr on or do I need to sand lightly first? I thought I had read somewhere on this thread that the behr paint likes to stick to the carc so I assumed I could just spray on the behr. I also have access to a paint booth for heated drying but I was wondering if 30's temps would have an adverse affect.
swiss
838
Oakwood, Ga
Thinned down with water, search on Zouts project posts and you will get a lot of hints on his techniques.
Woodsplinter
Phoenix/AZ
The CARC definitely needs to be clean- free of dust and grease. I sanded my deuce down with 220 grit to remove the oxidized paint and to smooth the texture of the CARC so I could apply a semi-gloss finish. The paint needs to be kept in the temperature range specified on the can for at least 24-48 hours in order to cure properly. 30's would be very bad.
Heating will speed the cure process, but I've noticed here in Phoenix that Behr takes about 30 days to cure to full hardness.
