M1008 won't come to life
sgrmaker
Lincoln/Vermont
I have replaced the starter solenoid and checked power at starter. The power cable to the starter shows 24v, the wire to the starter motor shows 24v with key on. No action from starter, no clicks, nothing. Used the truck with no problems just two days ago, started it up at least 3 times. Checked batteries with a load tester 1st and both seemed ok. The truck seems to go through the charging cycle, wait light goes out, nothing.
ABN173
11
FT Bragg, NC
Sir:
Is there anyway to check the resistors? or is it obvious that they are no good?
Don
Don,
I am no expert, just find it and remove it, if it is the same problem I had it should start without it. If you replace it and it again does not start then I would say that is your problem. It should be a 5 minute process to check it. Mine was pretty much fried just by looking at it.
Dale
BKubu
1,133
Gaithersburg, MD
Did it start when you test drove it? Did the seller mention any starting problems? I suggest starting there.
Ken_86gt
Williamsburg VA
If I am reading this right, you have 24V going to the starter solenoid when you turn the key? If so and you don't hear anything from the starter you could try hitting the starter with a hammer to jar the solenoid. Sounds like the solenoid isn't working and needs to be replaced. Could be a bad ground between engine and body or from the battery to the body as well?
