Russm
- 69
- 28
- Ft. Wainwright, AK
Noticed there is another topic describing almost the same problem as me, but in case its not the same cause, here we go:
Signalling Right flashes front and rear right signals. Braking does not affect the flashing.
Signalling Left flashes left signal on front but both signals on rear. Additionally pressing the brake causes front left and both rear signals to burn steady.
Switching on the hazard flashers is normal until brake is pressed, with brake pressed all 4 corners burn steady.
I've cleaned all grounds attached to headlights, front and rear lights. Cleaned the main ground under the dash on the driver side wall. All contacts on all bulb sockets have been cleaned. No lights are burned out.
The wiring harness going to the rear lights appears intact, with no visible wear or corrosion.
Other topic says the turn signal switch on steering column may need to be replaced.
Does anyone have anything else to try?
Thank you
Thank you
