M1009 alternator issues
RedneckMilenko
Memphis/TN
Alright, new batteries installed and a new gauge cluster. Since then now my GEN 2 light will not turn off and my GEN 1 light is very lightly flashing but not flasing in any kind of pattern. Also my lights to light up my cluster at night don't work but I think that's because of the LEDs I bought to replace them and they just aren't working out. I'm just wondering what's going on? I've already searched but everything I find that may even be useful is about the GEN 2 not working.
Warthog
231
OKC, OK
Did you use LEDs for the GEN lights? If so you messed up.
you need to test your alternators to see what is going on.
search for Barrman's alternator thread. While it is wordy, he covers testing of the units.
RedneckMilenko
Memphis/TN
Yes. I did use LEDs for the GEN lights. I didn't think it would've been an issue being as it'd still be completing the cuircut. I'll replace them with good bulbs as soon as I can, it won't be driven till then.
RedneckMilenko
Memphis/TN
Well I replaced the LEDs wih the regular bulbs and now both my GEN lights are telling me my alternators arent charging. All I did was replace my batterys, by belts, and put in a new gauge cluster, I didn't have any charging issues before this. Any ideas?
RedneckMilenko
Memphis/TN
I'd also like to add that wile relacing the belts I found that the driver side belt was the wrong size. The only way the previous owner could've put it on would be to take the alterntor off the braket and then slip the belt on. I'm having a very bad sqeel now as well from under the hood so I'm guessing the bearings are shot in it now and it needs ether rebuilt or replaced but I don't see why the other alt wont charge.
CARNAC
The Envelope Please.
619
Corpus Christi, TX
If it has too much play it will squeal and then usually stop after a minute or so. It would reappear if you turn the steering wheel if it is on that belt.
