M1009 alternator pictures
crownjewel4
Nanticoke, PA
Generator 1 went on my M1009. I removed both, and I am dropping them off to be rebuilt tomorrow. I wondered if anyone could be so kind and post pictures of the correct wiring placement for both Gen1 and Gen2, so when I reinstall, I can get the correct wires to the correct spots.
I should have taken pictures myself prior to, but did not.
Thanks in advance for the help,
:-o
bowtiecrazy
lake toxaway nc
these guys on here are good they will help you out i just wanted to say what i always take a pic with my cell phone(if you have one or digtial camera) when im workin on mine. i know that does not help u now but maybe it will in the future i have took mine off a couple of times and i cant never remember so i just lookat the pic good luck your at the right place.:razz:
Warthog
228
OKC, OK
This was just covered for the passenger side alt.
Look at the wiring diagram and it will show the correct wiring. In addition there is an extra wire for the drivers side not show. It is the black w/white wire that connects to the ground terminal. It is for the STE/ICE diagnostic plug.
http://www.steelsoldiers.com/cucv/49353-m1009-passenger-side-alt-connection.html
When you get them back make sure they installed the correct pullys. I had one worked on and the pully was wrong when I took it in. It needs to be 71mm in a stock system
